I recently decided to integrate some internally hosted websites into my Home Assistant dashboard using an Iframe Panel. While exploring different methods, I came across DuckDNS, which seemed like a great solution for dynamic DNS. However, I quickly realized that accessing internal network IP addresses through DuckDNS wasn’t straightforward. I tried setting up ZeroTier and WireGuard to create a VPN, but configuring them proved to be a bit challenging.
After some research and trial and error, I found that using a reverse proxy with Home Assistant’s built-in capabilities was the most seamless approach. This not only allowed me to access my internal websites securely but also kept my network setup clean without needing to punch additional holes in my gateway.
For anyone looking to achieve similar results, I’d recommend exploring Home Assistant’s proxy settings and considering more user-friendly VPN solutions if you’re not already comfortable with network configurations. It’s been a valuable learning experience, and I’m excited to continue expanding my smart home setup!
