Hello fellow Home Assistant enthusiasts! I’ve been diving into the world of KNX integration lately, and I wanted to share my experiences and some tips that might help others who are exploring this as well.
First off, I’ve been using KNX for my smart home setup, and it’s been a fantastic experience. However, I ran into a bit of a snag when trying to integrate a KNX scene into Home Assistant. Let me walk you through what I did and what I learned along the way.
I started by defining a scene in my knx.yaml file. The scene was supposed to control a set of blinds, and I was really excited to see it in action. Here’s how my configuration looked:
yaml
scene:
- name: “KNX Jalousie Sommer”
address: 0/1/0
scene_number: 3
After setting this up, I restarted the YAML files as instructed. To my delight, the scene appeared under the KNX extension in Home Assistant. But here’s where things got tricky—when I clicked on the scene, I received an error message saying it wasn’t available. Not only that, but the scene also didn’t show up as an entity when I tried to add it to a button.
I was a bit puzzled. Why wasn’t the scene working as expected? I double-checked my configuration, made sure the address and scene number were correct, and even tried restarting Home Assistant a few times. Nothing seemed to work.
After some research and reaching out to the community, I found out that the issue might be related to how scenes are handled in Home Assistant. It turns out that scenes need to be explicitly added to the list of entities you want to expose. This was a bit of a learning curve for me, but it made sense once I understood it.
To fix the issue, I had to modify my configuration.yaml file to include the KNX scene in the list of entities. Here’s what I added:
yaml
knx:
scene:
address: 0/1/0
scene_number: 3
After making this change and restarting Home Assistant, the scene finally appeared as an entity, and I could control it through the frontend. It was such a relief to see it working!
This experience taught me the importance of thoroughly checking the documentation and community forums when integrating new devices or scenes. Sometimes, the solution is just a matter of understanding how certain features are implemented in Home Assistant.
If anyone else is struggling with KNX integration or scene setup, feel free to reach out. I’d be happy to help troubleshoot or share more tips based on my journey. Happy automating! ![]()
