Hey everyone! I wanted to share my experience integrating the LG Hombot 3.0 vacuum cleaner with my Homematic system. It’s been a fantastic journey, and I hope this helps others looking to do the same!
I’ve always been a fan of smart home automation, so when I came across the LG Hombot 3.0, I knew I had to give it a try. The vacuum is not only efficient but also has some great features like obstacle detection and structured cleaning patterns. However, I wanted it to be fully integrated into my Homematic setup for seamless control.
The process wasn’t too complicated, but there were a few steps I had to follow to get everything working smoothly. First, I needed to ensure the vacuum had the latest firmware installed. This was straightforward using the LG support website. Once that was done, I moved on to setting up the WLAN connection.
I discovered that the vacuum supports several WLAN chipsets, but the Edimax EW-7811UN (RTL8192CU) worked perfectly for me. It’s compact and supports WPA2 encryption, which is a must for security. After purchasing the dongle, I formatted a USB stick to FAT32 and copied the necessary files onto it.
The next step was configuring the vacuum. I followed the guide to edit the wpa.conf file with my network details and made sure to set the correct IP address and DNS server. Plugging in the USB stick and restarting the vacuum did the trick, and it connected to my network without any issues.
Now, I can control the vacuum directly from my Homematic interface. It’s incredible how easy it is to schedule cleanings or start a session with just a button press. The vacuum even sends status updates, so I always know if it’s charging, cleaning, or paused.
One thing I found particularly useful was the ability to customize the web interface. I added a few scripts to make the integration even smoother, and it’s been running like a charm ever since. The vacuum has become an indispensable part of my smart home setup!
If anyone has questions about the setup process or needs help troubleshooting, feel free to reach out. I’d be happy to assist! ![]()
