Integrating Lutron RadioRa2 with Hubitat: My Experience and Tips
Hi there,
I’ve been diving into the world of smart home automation recently, and I must say, it’s been an exciting journey! One of the highlights has been integrating my Lutron RadioRa2 system with Hubitat. While the process has been smooth for the most part, there were a few hurdles I encountered along the way. I’d like to share my experience and some tips that might help others who are looking to do the same.
The Setup Process
I started by setting up my Hubitat Hub and connecting it to my Lutron RadioRa2 system. I only have the main repeater, which has telnet access. I didn’t need the Lutron Cloud Connect Bridge, so I focused on the telnet integration.
One of the first things I noticed was that Hubitat requires a list of all Lutron devices with integration IDs. I fetched this information as an XML file (DbXmlInfo.xml) from my Lutron system. The challenge here was figuring out how to use this XML file to set up the Hubitat integration.
Parsing the XML File
I looked into whether there was a tool that could parse the XML file and output the format Hubitat needs, which is called a ‘configuration list.’ Unfortunately, I didn’t find a readily available tool for this purpose. However, I discovered that manually extracting the necessary data from the XML file wasn’t too bad once I got the hang of it.
I spent some time going through the XML file to locate the integration IDs and other relevant information. It was a bit time-consuming, but I managed to compile the required list and set it up in Hubitat.
Tips for Manual Extraction
For those who might be in a similar situation, here are a few tips:
  1. Use a Text Editor: A good text editor with search functionality can make parsing the XML file much easier. I used Notepad++ for this purpose.
  2. Look for Patterns: The integration IDs and other device information often follow specific patterns in the XML file. Identifying these patterns can help you quickly locate the necessary data.
  3. Take Notes: Keep a notepad handy to jot down the device IDs and other details as you go through the XML file.
Automating the Process
While manual extraction worked for me, I can see how it might be tedious for others, especially those with larger systems. I’m currently exploring ways to automate this process, perhaps by writing a simple script that can parse the XML file and generate the configuration list automatically. If I make progress on this front, I’ll be sure to share my findings with the community.
Conclusion
Integrating my Lutron RadioRa2 system with Hubitat has been a rewarding experience. It’s allowed me to enhance my home automation setup significantly. While there were a few bumps along the way, particularly with parsing the XML file, the end result has been well worth the effort.
If anyone has questions or needs assistance with their own integration projects, feel free to reach out. I’d be happy to help!
Cheers,
