I’ve always been fascinated by the idea of integrating my hot tub into my smart home ecosystem, and after a lot of research and tinkering, I’m thrilled to share my journey with you!
For years, my Divine Sinclair hot tub has been a true oasis, but it was just that—a standalone luxury. I wanted to take it to the next level by automating its controls and monitoring its performance right from my phone. Enter Home Assistant (HA) and the Balboa Worldwide App MQTT Homie Bridge!### The Challenge: Decoding the Proprietary ProtocolThe first hurdle was understanding that my hot tub communicates over RS-485 using a proprietary protocol. Luckily, the community has cracked this code and made it accessible through open-source projects. I stumbled upon Balboa Worldwide App and its MQTT bridge, which seemed like the perfect solution.### The Setup: From DIY to Plug-and-PlayInitially, I went the DIY route, using an ESP8266 to relay RS-485 data over Wi-Fi. It was a steep learning curve, but incredibly rewarding. However, I soon discovered that a $24 RS-485 to Wi-Fi adapter could simplify things. I tested it, and it worked seamlessly! No more soldering or custom cables—just plug and play.For those on a budget, I recommend the $24 adapter. It’s a game-changer and eliminates the need for a Raspberry Pi setup. Plus, the Balboa Worldwide App now supports MQTT Auto Discovery, which means you don’t have to manually configure entities in HA. Talk about a time-saver!### The Results: Automation at Its FinestOnce everything was set up, I integrated my hot tub into HA using MQTT. I created switches for the pumps, lights, and temperature controls, and even set up automations to optimize energy usage. For example, I programmed the tub to heat up during off-peak hours when electricity rates are lower. It’s been running smoothly for months now!### Tips for Success1. Safety First: Always prioritize electrical safety. If you’re unsure about any wiring, consult a professional.2. Start Small: Begin with basic automations and gradually expand as you become more comfortable.3. Leverage the Community: Don’t hesitate to reach out to forums and GitHub repositories for support. The smart home community is incredibly helpful!### Final ThoughtsThis project has been a fantastic way to enhance my smart home experience. It’s not just about convenience—it’s about creating a more enjoyable and efficient lifestyle. I’m already brainstorming my next DIY project, but for now, I’m content with my glowing hot tub and the peace of mind that comes with knowing it’s fully integrated into my smart ecosystem.If you’re considering a similar project, I highly recommend giving it a try. The satisfaction of seeing your vision come to life is unparalleled! ![]()
