I recently came across a discussion where a user was trying to integrate their older Intermatic Home Automation setup, specifically the HA07C Master Remote and HA20C switches, with the SmartThings Hub. This is a common challenge for those with legacy systems who want to modernize without replacing all their hardware. The user mentioned they didn’t want to spend another $120 on new switches just for timed lighting functionality. This got me thinking about the possibilities and potential solutions for such integrations.
First, it’s important to understand that older systems like Intermatic’s might not natively support modern smart home platforms like SmartThings. However, there are often workarounds or third-party solutions that can bridge this gap. For instance, using a hub that supports both Zigbee and Z-Wave protocols could allow compatibility with a wider range of devices. Additionally, there are devices like the Hubitat Elevation that can act as a middleware, translating signals between older systems and newer smart home platforms.
I reached out to the community to gather insights and found that some users have successfully used virtual devices or custom rules within their hubs to mimic the functionality of older systems. For example, creating a virtual switch in SmartThings that triggers a scene or automation when activated could replicate the behavior of the HA07C Master Remote. This approach doesn’t require replacing the physical switches but leverages the hub’s programming capabilities.
Another angle to consider is the use of smart plugs or relays. If the user is comfortable with more hands-on solutions, installing smart plugs on their existing lamps could allow them to control the lights via the SmartThings app without needing to replace the switches themselves. This method is cost-effective and doesn’t disrupt the current setup beyond adding a plug.
It’s also worth exploring if there are any firmware updates or固件 updates for the Intermatic devices that might enable better compatibility with modern hubs. Sometimes, manufacturers release updates that improve integration with third-party systems.
In summary, while integrating older systems like Intermatic’s with SmartThings isn’t always straightforward, there are several creative solutions available. Whether it’s through middleware hubs, virtual devices, smart plugs, or firmware updates, there’s a path to modernizing legacy systems without a complete overhaul. If anyone has specific questions or needs help troubleshooting, feel free to reach out—I’d be happy to assist!
