Integrating PIR Sensors with HM Wired: Seeking Expert Guidance
Hello everyone, I hope this message finds you well! I’ve been working on integrating some PIR sensors into my HM Wired setup, and while the initial planning stage has gone smoothly, I’m now hitting a bit of a snag when it comes to the actual wiring and configuration. I’d love to hear from anyone who has experience with this or could offer some advice.
First, a little background: I’ve purchased these PIR sensors from eBay, and they’re supposed to be compatible with the HM Wired system. I’ve already installed them in various locations around my home, and the images I’ve attached give a good sense of how they’re positioned and what I’m aiming to achieve. My goal is to have these sensors trigger specific actions, like turning on lights or adjusting the thermostat, when motion is detected.
Now, the challenge I’m facing is understanding exactly how to connect these sensors to the HM Wired actors. I’ve been using direct connections so far, and I’ve set up a Raspberry-Matic as my CCU replacement. I also use HM Pocket Control on iPads embedded in the walls and on the iPhones of the household members for easy access. But when it comes to wiring the sensors, I’m a bit unsure about the best approach.
Specifically, I’m wondering about two main things: first, how to connect the sensor’s cables to the right actors to ensure that detected motion translates into the desired actions. Second, how to handle the power supply for these sensors. I have plenty of 0.6 and 0.8 mm wires lying around, and they’re all neatly organized in the distribution box, but I want to make sure I’m using the right setup to avoid any issues down the line.
I’ve looked through some forums and guides, but I’m still not entirely confident about the exact steps I need to take. For example, should I be connecting the sensors directly to the actors, or is there a better way to integrate them into the existing system? Also, is there a recommended way to test the setup once everything is wired up to ensure that everything works as intended?
I’d be incredibly grateful for any tips or advice anyone might have. Whether it’s about the wiring process, the configuration in the HM system, or best practices for ensuring reliability, I’m all ears. I’m really excited about completing this project, and I’m sure it’ll add a whole new level of convenience to my home. Thanks in advance for your help!
Best regards,
Wolfgang
