I recently decided to enhance my home security setup by integrating my Reolink camera with my Google Nest Display. The process was straightforward, and I thought I’d share my experience in case anyone else is looking to do the same.
First, I installed the Reolink camera as per the instructions. The setup was quite user-friendly, and the camera’s video quality exceeded my expectations. The next step was connecting it with my Google Nest Display. Initially, I encountered a few hiccups when trying to create an automation that would display the live feed whenever the doorbell rings.
After some research and troubleshooting, I realized the issue was related to the URL settings in my Home Assistant configuration. I made sure the URL was accessible from the Nest Display and adjusted the settings to ensure compatibility. Once that was sorted, the integration worked seamlessly.
Here’s a quick tip for anyone attempting this: ensure your Home Assistant instance is properly configured with the Google Cast integration. This was key in resolving the blue cast icon issue I faced initially.
The final setup is fantastic. Now, whenever someone rings the doorbell, the Nest Display automatically switches to the Reolink feed, allowing me to check who’s there without missing a beat. It’s a great addition to my smart home setup and has definitely added a layer of convenience and security.
If you’re looking to integrate a Reolink camera with your Google Nest, I highly recommend giving it a try. With a bit of patience and the right configuration, it’s a breeze!
