Integrating Shelly Devices for Garage Door Control
I recently decided to upgrade my home automation setup by integrating Shelly devices to control my garage door. After some research, I found that using a Shelly 1 Gen4 along with a Shelly Plus i4 DC was the perfect combination for my needs. The Shelly 1 Gen4 handles the actual opening and closing of the garage door, while the Shelly Plus i4 DC, with its built-in sensors, keeps track of the door’s status—whether it’s fully open, closed, or in motion.
One of the challenges I faced was ensuring smooth communication between the two devices. Initially, I tried using Webhooks, but it wasn’t as reliable as I hoped. After some experimentation, I discovered that MQTT was the more efficient method for this setup. By configuring MQTT on both devices, I was able to create a seamless connection that updates the garage door status in real-time within the Shelly app.
I also wanted to add a visual indicator for the garage door’s status. This required a bit of scripting, but with the help of some online resources, I managed to set up a system where the Shelly 1 Gen4 displays a symbolic status in its web interface. This feature has been incredibly helpful, as it gives me a clear overview of the garage door’s state without needing to check multiple apps.
For those looking to replicate this setup, I recommend starting by thoroughly reading the device manuals and exploring the MQTT configuration options. It’s also worth checking out the Shelly community forums, where I found a wealth of information and support. If you’re considering integrating Shelly devices into your smart home, I highly recommend giving this a try—it’s been a game-changer for me!
Thanks to everyone in the community for their helpful tips and guidance. It’s amazing how a supportive community can make such a difference in projects like these. Happy automating!
