Integrating Smart Door System with Z-Wave Automation
Hello everyone, I’m excited to share my recent project of integrating a smart door system with Z-Wave automation. I’ve been exploring ways to enhance my home security and convenience, and this setup has been a fascinating journey.
My apartment uses an audio intercom system for opening the building door. I wanted to integrate this with my SmartThings hub to enable remote access. After some research, I considered two options: using a Wi-Fi controlled switch or a servo motor to physically press the button. While the servo option seemed intriguing, I was concerned about the mechanical reliability over time.
I decided to go with a Wi-Fi controlled switch, specifically the Sonoff, but faced challenges with voltage compatibility since the system uses DC. I reached out to the community for advice and received some excellent suggestions. One user recommended checking if the system supports dry contacts, which would simplify the integration.
In the meantime, I’ve been experimenting with Z-Wave automation for my lights. I set up a rule where the lights turn on when I press a physical switch, even if the hub is off. This ensures safety and convenience for visitors. However, I encountered an issue where the virtual switches in WebCORE weren’t responding as expected. I’m curious if others have faced similar challenges and how they resolved them.
I’m also considering upgrading my thermostat to a Honeywell WiFi model and integrating it with my existing system. I’m wondering if there are any known issues with this setup, especially regarding compatibility and performance.
If anyone has insights or tips on these projects, I’d greatly appreciate your input. Whether it’s about the smart door integration, Z-Wave automation, or thermostat setup, your experiences would be invaluable. Looking forward to hearing from you all!
