Hey everyone, I’m really excited to share my experience with integrating smart lighting into my home using OpenHAB and custom automation. I’ve been experimenting with different setups and wanted to document my journey in case others are looking for inspiration or guidance.
First, I connected an LED strip via a Fibaro RGBW2 controller. My goal was to control the dimming levels using a Hue Dimmer switch. I managed to set it up so that each ‘dim-up’ click increases the brightness by 0.10, and each ‘dim-down’ click decreases it by -0.10. It took some time to figure out the right flow configuration, but I’m thrilled with how smooth it works now!
I also wanted to share a tip I discovered while troubleshooting. If you’re having issues with device compatibility or integration, checking the logs in your OpenHAB setup can be incredibly helpful. For example, I encountered an error with a sensor where the value couldn’t be converted to a float. By reviewing the logs, I was able to identify the problematic data point and adjust my flow accordingly.
Another thing I’ve been exploring is local processing for my Z-Wave switches. I set up a local app to control over 35 switches with a minimote button. Initially, it worked perfectly, but after adding around 25 switches, the app stopped responding. I’m curious if anyone else has experienced this limitation and if there’s a workaround or best practice to handle larger setups.
On a lighter note, I’ve also been experimenting with custom scripts for my blinds. I created two scripts for ‘aufblenden’ and ‘zublenden’ modes, which automatically adjust the blinds to specific positions. It’s been a fun challenge to integrate these with Alexa voice commands. I’m now working on optimizing the commands to make them more intuitive and user-friendly.
If anyone has tips on improving automation reliability or suggestions for integrating more devices seamlessly, I’d love to hear your thoughts! Happy tinkering everyone! ![]()
