Integrating Smart Plugs for HVAC Dampers: A Feasibility Exploration
I’ve been exploring innovative ways to enhance my home’s HVAC system, particularly focusing on room-by-room temperature control. After experimenting with Keen vents and now considering Flair, I’m curious about the viability of using motorized HVAC dampers connected to smart plugs or relays. This approach would allow dampers to turn on or off based on temperature readings from Ecobee sensors or similar devices, potentially offering a cost-effective alternative to installing a control board for each damper.
The idea is to use smart plugs or relays to manage the dampers, which could be triggered by temperature data. For instance, if an Ecobee sensor detects a room temperature below a set threshold, a rule could automatically open the corresponding damper to increase airflow. This setup could be managed through basic rules or even Rule Machine (RM), making it accessible for those without extensive technical expertise.
I’ve come across products like the MHCOZY Self-Lock Momentary Interlock Controller and Suncourt motorized dampers, which seem promising. These devices could potentially eliminate the need for additional wiring or complex installations. However, I’m unsure about the reliability and scalability of this approach, especially with multiple dampers in use.
Has anyone successfully implemented a similar system? I’m particularly interested in understanding the practicality of polling Ecobee sensors and integrating the data into a rule-based system. Any insights or experiences would be invaluable as I consider this innovative solution for achieving better temperature control in my home.
