I’ve been diving into the world of home automation lately, and I’m really excited about how far things have come! One of my recent projects has been trying to combine a smart switch with the Bond Bridge to create a seamless setup that works both hands-free and with a physical switch. I wanted to share my journey and see if anyone else has tackled something similar or has tips to share.
So, here’s the deal: I have an Inovelli smart switch that I wanted to integrate with my Google Assistant. The goal was simple—use voice commands to control the fan, but also keep the physical switch functional so that anyone in the house can use it without messing up the setup. Initially, I set up the switch to always be on power, thinking that it would just act as a manual override. But here’s where things got tricky.
The issue I ran into was that when someone used the physical switch to turn the fan off, it would disconnect the remote control functionality. That meant I’d have to go through the whole process of turning the power back on and resetting the fan speed every time someone accidentally turned it off. It became a bit of a pain point, especially with guests or family members who weren’t tech-savvy.
After some research, I stumbled upon the idea of using a Bond Bridge to mediate between the smart switch and the existing remote control. The plan was to set up a rule where pressing the physical switch wouldn’t cut the power but would instead send a signal to the Bond Bridge, which would then adjust the fan settings accordingly. It sounded a bit complex, but I thought it was worth a shot!
I started by configuring the Inovelli switch to always remain powered. Then, I set up a rule in the Bond Bridge that detected when the physical switch was pressed and used that trigger to adjust the fan’s settings through Google Assistant. It took a few tries and some tweaking, but eventually, it started to work! Now, pressing the switch doesn’t disrupt the automation—it simply triggers the predefined actions, and the fan behaves exactly as it should.
This setup has been a game-changer for me. It means that everyone in the house can use the fan without worrying about breaking the automation, and I don’t have to constantly troubleshoot or reset anything. Plus, it’s been a great learning experience in terms of understanding how different devices can work together in a smart home ecosystem.
I’d love to hear from anyone else who’s tackled a similar project or has tips for improving this setup. Have you found a way to integrate physical switches with smart systems seamlessly? What challenges did you face, and how did you overcome them? I’m always looking for new ideas and optimizations, so please share your experiences!
