I’ve been on a quest to integrate my smart thermostats with Google Assistant, and I thought I’d share my journey and findings with the community. While the process has been mostly smooth, there have been a few bumps along the way that I wanted to explore in more detail.
Initially, I followed the instructions provided in the official OpenHAB documentation for Google Assistant integration. I created a group containing my three thermostats, as suggested, and exposed them to myopenhab. However, despite everything appearing correctly in the myopenhab interface, Google Assistant wasn’t recognizing my thermostats. This was a bit perplexing, especially since I had successfully integrated lighting and switchable items using the same setup.
After some research and experimentation, I discovered that the key was to ensure that each individual item within the group was properly exposed, not just the group itself. By exposing each thermostat separately, Google Assistant was finally able to recognize and interact with them. This was a crucial insight that I wish had been more clearly outlined in the documentation.
I also found that organizing the items into meaningful groups within Google Assistant’s Smart Home settings greatly improved the user experience. For instance, grouping all heating devices together made it easier to control them with voice commands like, “Hey Google, set the temperature in the living room to 72 degrees.”
Another thing worth noting is the importance of consistent naming conventions. I initially used different names for my thermostats across OpenHAB and Google Assistant, which led to some confusion. By standardizing the names, I eliminated any ambiguity and made the integration process much smoother.
This experience has been a great learning opportunity, and I’m now more confident in tackling similar integrations in the future. I’d love to hear from others who have successfully integrated their thermostats or have tips on optimizing the setup process. Happy tinkering!
