Integrating Solar Energy and Water Monitoring with Homematic
I’ve been on a journey to integrate my home’s energy and water systems with my Homematic setup, and it’s been both exciting and challenging. Let me share some of my experiences and insights!
First, I wanted to monitor my solar energy production more effectively. I came across a solution where I could connect my Solarview system to Homematic. The goal was to optimize my self-consumption and track energy usage in real time. After some research and tinkering, I managed to set it up, and it’s been working beautifully! Now, I can monitor how much solar energy I’m generating and using directly from my Homematic interface.
Another project I undertook was building a water meter sensor. Inspired by a tutorial, I created a system using an ESP8622 and a proximity sensor. The setup involved a bit of trial and error, especially with the YAML configuration. I had to adjust the voltage from 12V to 5V to ensure stability. The final result was a reliable water monitoring system that integrates seamlessly with my energy dashboard. It’s incredibly satisfying to see the data flow in real time!
For anyone looking to embark on similar projects, I recommend starting with clear goals and doing thorough research. Don’t hesitate to reach out to the community for help—there are so many knowledgeable people willing to share their expertise. Also, always prioritize safety, especially when dealing with electrical components.
I’m now exploring the possibility of adding more sensors and automations to my setup. The journey is far from over, but each step brings me closer to a smarter, more efficient home. If you’re considering integrating your energy or water systems, I say go for it—it’s a rewarding experience!
Happy tinkering! :rocket:
