Integrating Solar Inverter with Home Assistant: A Step-by-Step Journey
I’m thrilled to share my recent journey of integrating my SAJ solar inverter with Home Assistant. While the process was a bit challenging, it ultimately taught me a lot about modbus communication and configuration. Here’s what I learned along the way:
Initially, I tried using a USB-RS485 converter with modbus configuration, but the inverter wasn’t responding as expected. I noticed some irregularities in the modbus poll logs, which made me question whether the communication protocol was compatible with my setup. After some research, I discovered that the SAJ Modbus Communication Protocol I found online was intended for newer models, and my inverter, purchased in 2013, didn’t have the same specifications.
I then experimented with a serial to ethernet converter (USR TCP232-410s) to see if that would bridge the gap. Configuring the converter and updating the Home Assistant settings seemed promising, but unfortunately, Home Assistant wouldn’t boot correctly with these changes. It turned out the converter didn’t have a web server, which was essential for the integration to work seamlessly.
After some trial and error, I realized that my approach needed adjustment. I decided to focus on understanding the inverter’s specific communication requirements and how they interact with Home Assistant’s modbus integration. This led me to explore different modbus configurations and test various register addresses to find the right combination that would work with my setup.
I also reached out to the community for advice, and it was incredibly helpful to connect with others who had similar experiences. One user, fredericvl, provided some valuable insights that helped me refine my configuration. Their expertise was a game-changer in troubleshooting the communication issues.
Ultimately, the key takeaway for me was the importance of thoroughly understanding the device’s specifications and communication protocols before diving into integration. It’s a reminder that patience and persistence are crucial when working with hardware and software that might not always play nicely together.
I’m excited to continue exploring Home Assistant’s capabilities and look forward to sharing more insights as I expand my setup. If anyone has questions or wants to discuss their own integration challenges, feel free to reach out—I’d be happy to help!
