Integrating Wyze Cam on Brick Walls: Tips and Success Story
Hi everyone, I wanted to share my experience with installing a Wyze Cam on a brick wall. After doing some research and testing different adhesives, I found a solution that works perfectly! I used a combination of heavy-duty adhesive pads and silicone-based glue. This not only kept the camera securely in place but also allowed for easy repositioning if needed.
For anyone else looking to do this, I recommend checking the surface for any rough areas and ensuring it’s clean before applying the adhesive. Also, consider the camera’s placement for optimal coverage. I’ve been using this setup for a few weeks now, and it’s held up beautifully through various weather conditions.
Would love to hear if others have tried similar setups or have additional tips! :hugs:
