Integrating Zigbee Devices: A Learning Journey
I’m currently diving into the world of Zigbee devices and have encountered an interesting challenge with my Aqara contact sensor. While most channels are functioning smoothly, the ‘contact’ channel isn’t returning the expected values. After some research, I found a potential solution involving a JSON conversion script, but it hasn’t worked as hoped. Here’s what my configuration looks like:
java
(function(x){
var result = “”;
var json = JSON.parse(x);
if (json.contact) {
result = “CLOSED”;
} else {
result = “OPEN”;
return result;
})(input)
I also tried adjusting the transformation pattern directly in the channel settings, but no luck there either. It’s a bit puzzling, and I’m curious if anyone else has faced a similar issue or has a workaround in mind.
On a lighter note, integrating these devices has been a fascinating journey. Each challenge I overcome feels like a small victory, and it’s amazing to see how everything comes together to create a seamless smart home experience. If anyone has tips or tricks for troubleshooting Zigbee devices, I’d love to hear them!
Cheers,
