If I want to cut and re-connect segments of the T2 led strip for a bookshelf or media center… what kind of connector would I need? Can’t really seem to find a concrete answer.
Say for example, I want right angle connectors for the back of a bookshelf, but then I’ll need extra wiring to add segments for each shelf. What would I need?
Dimmer Switch H2 uses phase-cut dimming to control conventional dimmable lights, so it is not compatible with direct dimming of smart lights like the LED Downlight T2.
You can adjust the T2’s brightness, color temperature, and color through the Aqara Home app or use the Aqara Touchscreen Dial V1 for physical control.
We currently don’t offer dedicated connectors or extension kits for the T2 LED Strip.
Could you share a bit more about the type of connectors or extension kit you’re looking for and how you’d like to set up the strips on your bookshelf or media center? If you have any reference pictures, feel free to share them as well! That would help us better understand your needs.
Hi, its a pitty and makes no sense to not have this function on Aqara H2 Dimmer switches. Just imagine every time you need to dim Your lights you need to do it via the app if you dont own Aqara Touchscreen Dial V1. And if you have frame with 5 55 mm switches in Europe on it Aqara Touchscreen Dial V1 wont even fit. I think lot of users are missing such features on Aqara Dimmers…
Lucky enough to receive the Permanent Outdoor Lights H1 and very impressed so far. But I’m trying to create a couple of scenes before posting my review. In the effect editor using Custom Segments (or the DIY Drawing) is it possible to have some segments off entirely whilst others are on?
I ask because at late night I only want the lower roof section lit and the upper roof which is outside our bedrooms to be off.
Many thanks and will post a full review with photos shortly.
AQARALIGHT11 ging gestern noch (ich habe damit -20% bestellt), heute gehen beide Codes nicht mehr, aber die BF-Preise sind genau um die 20% gesunken, ist quasi schon ohne Code eingepreist.
For the permanent outdoor lights if you go to Add Static Effect and set the mode to DIY Drawing you can select which lights you want lit and which you want to stay off. You can then save this as a custom effect This should get you the late night effect you want.
Just to make sure I understand, are you looking for a wireless rotary dimmer with both Zigbee and Thread support? Also, what price range would you consider reasonable for a product like this? We’d love to hear your thoughts!
I really enjoy my new Aqara Floor-Lamp-T1 and am thankful of having had the opportunity to get it as part of the early trial! My kids really love the music sync feature so I spent some time to bring support over Matter to Home Assistant. Here’s the full write-up with video
@Louise Around 35–40 euros for a wireless knob switch—like the Aqara Wireless Knob Switch H1—which would be a great fit for the Floor Lamp T1 in the background.
