The FP1 presence sensor seems to lose presence detection when laying down on the couch. Is there a way to make this more reliable?
@ryfsv77pzd Hey there! Great question — this is actually a pretty common scenario with the FP1. When you’re lying down, your micro-movements (especially breathing) become much harder for the radar to pick up compared to when you’re sitting or moving around.
A few things that should help:
Installation angle matters a lot. For detecting someone lying down, wall-side mounting generally works better than ceiling mounting since it gives the radar a clearer view of your torso movement. If it’s ceiling-mounted, the detection range is smaller and stationary/lying targets are trickier to keep locked. If your couch is against a wall, try mounting the FP1 on that side wall, slightly tilted downward toward the main seating area — around 2m height with the radar angled to cover where your chest would be.
Tune your sensitivity settings. Bump up the “Presence Monitoring Sensitivity” in the app so it picks up subtler movements. Higher sensitivity helps maintain detection when you’re still, though you may need to balance it against false triggers from things like curtains or distant vibrations.
Check for interference. Make sure there aren’t fans, AC vents, or moving curtains between the sensor and your couch — these can confuse the radar and cause dropouts. If you can’t avoid them, mark those areas as interference zones or edges.
Run Space Intelligent Learning. Do this when the room is empty — it helps the FP1 learn the static environment and reduces background noise that might be masking your presence.[“content_id:4”]
If you’ve tried these and it’s still flaky, there might be something specific about your room layout or the couch material causing issues. Feel free to share more details and the community can troubleshoot further
