Is Your Matter Device Acting Up? Here’s My Quick Fix Journey!
Alright, so I had this super annoying issue where my Aqara Motion Sensor kept ghosting me in Apple Home. One minute it’s there, next minute—it’s gone. Tried the usual unplug-replug dance, even reset it three times. No dice.
Then I stumbled on the most random fix: I moved my border router (a HomePod Mini in my case) just two feet closer to the sensor. Bam, instant reconnection. Turns out Matter is totally picky about distance and mesh placement, especially if you’ve got metal cabinets or a thick wall in the way.
Also, switching off Wi-Fi on some 2.4GHz-saturated devices helped reduce interference. Didn’t expect channel overlap to be that big a deal, but it was.
Sharing this here in case anyone else is pulling their hair out. Don’t always blame the device—it might be your environment playing tricks.
Anyone else found weird little fixes like that?
@RobotRoomie Hey there! Thanks for sharing your experience—this is super helpful for the community! :raised_hands:
Your story is a great reminder that sometimes the smallest adjustments (like moving a border router just a couple of feet or tweaking Wi-Fi interference) can make a huge difference with Matter devices. Metal obstructions and thick walls are notorious for causing headaches, so your fix makes total sense.
I’ve heard similar stories where folks resolved flaky connections by:
  • Repositioning Thread routers to create a better mesh path.
  • Changing Zigbee channels to avoid Wi-Fi overlap (since both often use 2.4GHz).
  • Even swapping out USB 3.0 hubs near hubs/routers (they can cause RF interference!).
Glad you found a solution, and hope this helps others troubleshooting! Keep the weird fixes coming—they’re gold. :smile:
When I change the zigbee channel I need to repair all the Aqara devices, is there a way for them to automatically move?
@nickeliah1 You seem to be experiencing an issue where you need to re-pair all Aqara devices when changing the Zigbee channel. You can contact customer support for assistance. Contact the Aqara Home App Customer Service Team (Profile> Help & Feedback > Customer Service) or scan the QR code:
