Hi everyone,
Many of us are installing radiator thermostats right now. If you pair one with a Climate Sensor W100, the idea is simple: the W100 hangs on the wall and measures the real room temperature, and the thermostat on the radiator uses that value instead of its own.
I recently found out that in two of my rooms this link was not active at all, although I was sure I had set it up. The thermostats were happily using their own sensor, and I had not noticed for days. So here is a quick check that anyone can do without tools.
Why the link matters
The thermostat sits right on the radiator. When the radiator is hot, the air around it is much warmer than the rest of the room. In one of my rooms the difference was almost 4 degrees:
- W100 on the wall: 20.3 °C
- Sensor inside the thermostat, radiator running: 24.0 °C
The radiator there sits under a window sill, where warm air collects. A thermostat that only trusts its own sensor believes the room is warm long before it really is.
The check
Step 1: Compare the two numbers.
Open the W100 in the Aqara Home app and note the temperature. Then open the thermostat and look at the current temperature it shows.
- If both numbers are the same, or only 0.1 degrees apart, the thermostat is showing the W100 value. Good.
- If they differ clearly, the link is probably not active.
In my two unlinked rooms the numbers were up to 3 degrees apart. After I linked them, all thermostats matched their W100 almost exactly.
Step 2: Do the check while the radiator is warm.
This is the part I got wrong at first. When the radiator is cold, both sensors measure nearly the same temperature anyway, so the numbers match even without a link. Only a warm radiator shows the difference.
Step 3: Look at the W100 page.
On the W100 page in the app, my linked thermostat appears under “Linked Devices”. If nothing is listed there, the two devices don’t know about each other.
Step 4, optional: Switch the source once.
In the thermostat settings you can choose which temperature source it uses. Switch it to the internal sensor for a minute and watch the number. With a warm radiator it should jump up. Switch back to the W100 and it should drop to the room value again. In my test: 20.4, then 24.0, then 20.4 again.
What this check does and doesn’t tell you
It tells you that the thermostat receives and displays the W100 value. That is the basis for everything else.
It does not tell you how the valve regulates afterwards. For the W600 there is a separate, longer discussion about that in this forum: W600 external sensor does not control valve – firmware issue. I don’t want to mix the two topics. But before anyone looks into regulation, this simple link check should come first, because a missing link is by far the easiest thing to fix.
Where to put the W100
A few things that worked for me:
- not directly above or next to the radiator
- not in direct sunlight
- not on a cold outside wall
- roughly at chest height, where you actually feel the room temperature
Has anyone else found a thermostat that was quietly running on its own sensor? I’d be curious how you noticed.
Frank
