[ISSUE] FP300 Unable to Switch to Zigbee Protocal - Download failed (Code: -1002)
After 10 quick presses, it did work now, and is connected to my M2 hub
Its now fixed.
Not for me it’s not. I’m in Spain. Factory reset, region set to default: ā€œOtherā€ (I’ve tried Spain too unsuccessfully), Bluetooth good, WiFi good, no VPN, device detected, switch to Zigbee, confirm switch, but it never progresses beyond 0%. No error, no timeout - just sits there. I’ve tried countless times, even leaving it for over an hour. On the point of giving up.
j’ai changĆ© le serveur de chine en france, j’ai change en zigbee, je suis revenu en serverur france et j’ai reussi instaler le capteur en zigbee avec M1s hub
Hello, are you in the blue light flashing in the distribution time window? If it has been launched, please try to reset the device by pressing and holding for 5s, and then try to add and select protocols.
ā€œnever progresses beyond 0%ā€ during this, you could try to click the button once and see if it rebulid the connection to the hub.
