Issue with M100 Hub
Ii have the M100 hub & I keep getting 10036 error everytime I try setting it up.i have not changed regions. I had connected it through Apple Home before & removed it. Any help would be appreciated
Welcome to the forum
10036 is a service-region error, not a hub fault. Two Experts said the same in other threads (#358836, #354766). Where did you buy the hub, and what region is your Aqara account set to? If they don’t match, that’s your problem. In #358836 the fix was putting the account on the region the support request asked for, logging out and back in, resetting the hub, and re-adding it. If it still throws 10036, email support@aqara.com with the hub serial number.
I encountered the same error message when setting up an Aqara Doorbell 400 the other day on the EU server. I tried adding it to the Aqara app using a PoE network connection, but received error code 10036. I then unplugged the network cable from the PoE injector—leaving only the power supply from the PoE cable—and was able to connect it via Wi-Fi.
Not sure what the issue was; I didn’t investigate further. I tested an Aqara G5 PoE—it worked fine on the same cable.
