Issues with G350 - keeps telling me my WiFi password is correct
We bought a G350 several months ago. After not having used it for some weeks, I plugged it back into the power socket, yet it keeps telling me that the WiFi password is incorrect. I tried
resetting the device several times but no luck either.
The password is however 100% correct so no clue what’s wrong and how to fix this. Any idea?
Try setting your network settings to 2.4Ghz only.
Also make sure you are scanning the correct QR code. I remember going through this.
Hey there.the G3 and G350 uses both 2.4Ghz and 5
ghz bands so it shouldn’t be an issue or to switch to 2.4Ghz band.i suggest pressing 10 times in the power button and let it factory reset as by only pressing the power button for 5s will not factory reset it.also make sure you phone is also connected on the same WiFi witch you want to pair the G350
Right, it shouldn’t.
Edit to add: I had to switch my network to 2.4 only in order to set mine up. It worked. I just figured that my phone was on the 5 and the hub was on 2.4. Is that a possibility?
Is it possible that you switched or logged in in the wrong region / server?
If you refer to the G350 doesn’t need an hub to can be added so once you reset it it will give you to chose what band you want to connect it then sure you need to chose the band on what your phone is connected it doesn’t chose the band automatically.at meat on my G3 I just chided the 5Ghz directly since my iPhone was already connect to that band and it worked and pair it perfectly.
