Jasco Dimmers Resuming Dim Level When Turned On via Wall Switch
Hey everyone,
I’ve recently installed a bunch of GE/Jasco dimmer switches in my house, and they’ve been working great so far. However, I’ve noticed an interesting behavior that I’d like to address. When I dim a light using SmartThings and then later turn it off, if I press the wall switch to turn it back on, it turns on to the dim level it was previously set to. While this might be useful in some scenarios, I’d actually prefer it to always turn on to 100% when I press the wall switch.
I know I could achieve this using WebCore, but I’m wondering if there’s a simpler way to set this at a hardware level or if there’s an easy setting in SmartThings that I’m missing. Has anyone else encountered this behavior or found a straightforward solution?
I’d love to hear if others have faced similar issues or if there’s a setting within SmartThings that can adjust this behavior without needing additional apps or workarounds. Thanks in advance for your insights!
Best regards,
