LED Bulb T2 Guide
Here is a guide for the LED T2 bulb. Hopefully it is useful for someone and as ever, there is a PDF version for download if you need it for your records.
LED Bulb T2.pdf (224.5 KB)
Aqara Smart Home Info Sheet Series
Aqara LED Bulb T2 – Smarter Light, Greater Comfort
Overview
The Aqara LED Bulb T2 is a smart, energy-efficient bulb that delivers adaptive, natural lighting to suit your lifestyle. It’s available in four versions to fit different needs and fittings:
• T2 White (E27) – Tuneable white light, Zigbee + Matter over Thread
• T2 Colour (E27) – Full RGB colour + tuneable white, Zigbee + Matter over Thread
• T2 White (GU10) – Compact tuneable white spot bulb, Zigbee + Matter over Thread
• T2 Colour (GU10) – Full RGB colour + tuneable white spot bulb, Zigbee + Matter over Thread
Each model connects via Matter over Thread for platform flexibility, or Zigbee for enhanced control within the
Aqara ecosystem.
Colour Temperature: 2700K – 6500K (Tuneable White)
Brightness: Up to 806 lumens (60W equivalent, E27 models)
Power: 8W
Integrations: Aqara Home, Apple Home, Alexa, Google Home, Matter
Control: App, voice, automations, or paired Aqara switches
Ratedness & Reliability
• Indoor use – Ideal for bedrooms, living rooms, kitchens, and hallways.
• Dual connectivity:
  • Zigbee (via Aqara Hub): Enables full control, advanced automations, and smooth transitions.
  • Matter over Thread: Seamless multi-platform support with local reliability.
• Smooth dimming – Gradual fade in/out (Zigbee only).
• Energy efficient – 8W with up to 25,000-hour lifespan.
• Works locally even if Wi-Fi is unavailable.
Accessibility & Ease of Use
The T2 bulb enhances independence and comfort for users with mobility, vision, or sensory limitations.
■ Hands-free control – via Siri, Alexa, or Google Assistant.
■ Visual feedback – Lights can flash or dim for notifications.
■ Adaptive brightness – Adjust automatically by time of day.
■ Scene-based simplicity – Combine bulbs with Mini Switches for easy physical control.
Example:
• Single press: Bright, cool daylight.
• Double press: Relax mode – 30% brightness, 2700K.
• Long press: Lights fade off slowly before bed.
Practical Scenarios
Scenario Use Case Example
Bedroom Wake-up & bedtime lighting Gradually brightens at 7AM, dims warm at 10PM
Living Room Mood & scene control Double press Mini Switch → Movie Mode (20%)
How to Set Up Automations – Aqara Home (Zigbee Mode)
Example 1: Toggle the light with a Mini Switch
  1. Open Aqara Home.
  2. Tap Mini Switch → 3 dots at top right → Configure Automations → + Add.
  3. WHEN: Add Trigger → Accessories → Mini Switch → Single Click.
  4. THEN: Add Action → Accessories → [Choose Light] → On/Of
  5. Save.
Example 2: Wake-Up Light
  1. WHEN: Add Trigger → Time → 07:30 AM/Sunrise
  2. THEN: Accessories → Bulb T2 → Brightness 100%, 5000K.
  3. Add Gradual Brightness Increase (Zigbee only).
  4. Save.
Example 3: Sleep Mode
  1. WHEN: Add Trigger → Time → 10:00 PM/Sunset.
  2. THEN: Accessories → Bulb T2 → Brightness 20%, 2700K.
  3. Add ‘Fade Out over 30 seconds’ (Zigbee only).
  4. Save.
How to Set Up Automations – Apple Home (Matter over Thread)
Example 1: Relax Scene
  1. Open Apple Home → + at top right → Add Scene → ‘Relax.’
  2. Add Bulb T2 → Brightness 30%, Warm White.
  3. Assign Mini Switch → Double Press → Run Scene.
  4. Done.
Tips for Best Use
• Use Zigbee with an Aqara Hub for smoother fades and advanced automations.
• Use Matter over Thread for wide compatibility and fast, local control.
• Match light tone to your activity:
  • 2700K Warm White: Evenings & relaxation
  • 4000K Neutral: Everyday use
  • 6500K Cool White: Focus & work
• E27 bulbs – for lamps and ceiling fittings.
• GU10 bulbs – for spotlights and recessed lighting.
Final Thought
The Aqara LED Bulb T2 family offers intelligent, adaptive, and accessible lighting for every space. With four versions, dual connectivity (Zigbee + Matter over Thread), and deep automation control, it delivers the perfect balance of comfort, flexibility, and smart precision.
Nice write up!
I still think there is a massive piece of functionality missing from the T2’s and that is linking to Alexa when in Zigbee mode using the Alexa Skill.
When is Matter / Thread mode, you can simply say “Alexa turn off name of bulb” and all works. However, when using Zigbee mode which gives more functionality and allows for MARS pairing when used with say a V1 or H2 switch, does not pass through the bulb details to Alexa using the Skill.
Aqara, is this something that will be coming soon or should I give up on this and link the M3 into Alexa and use the Matter bypass (really trying to avoid this as the Skill works for all other Aqara devices).
Thanks
I got a T2 bulb this weekend and it works great. I use it with a FP2, when I’m in the living room the T2 turns up, when I’m not the T2 turns off. :laughing:
Yes, the T2 is very good when paired with a presence sensor like the FP2, P1, P2 and will be particularly good with the upcoming FP300. Also when paired with a door and window sensor, the pairing is particularly good in cupboards and closets making a very convenient automated process.
The T2 bulb with Matter also supports native smooth fades (transitions) and you can create advanced automations and alter settings like the power-on behaviour, although that’s going to depend on the smart home platform used if it exposes those features to the user or not.
Google Home, Alexa or Apple Home do not support creating transitions (although Apple’s Adaptive Lighting uses them internally), Home Assistant does, SmartThings only partially unless you create a custom driver, IKEA Home Smart partially too (it can schedule wake-up and wind-down transitions but not launch them on demand with a button for instance).
These are perfectly valid points and I considered putting a little bit more detail in, however the little guides that I am writing are designed for brand-new users who I believe would prefer to keep things simple. However, from people like yourself commenting and the comments like the one you have made means that they also get valuable information so thank you very much for your comment as this may also help someone who wants to become a more advanced user. Hope you have an amazing day.
This was quite an effort. Thank you. I added this info to my home AI instance so it better understands these bulbs. Here I will add my 2 cents. I had to move all my Aqara T2 bulbs to Zigbee as every time I powered the bulbs off it was disturbing my very robust Thread network. I wish that Aqara would make the networking stay active when the bulbs are off just like Zigbee mode. The power savings is not worth the trouble
Thank you for your kind comment. I agree, Zigbee is better in my opinion. I know that everybody fawns over thread, but I just don’t think it can properly compete with the rock solid performance of Zigbee.
