The LED Light Bulbs T2 are intermittently connecting to Alexa making the voice activated automations through Alexa not function. For example, I have 3 Aqara light bulbs in my bedroom and a voice command to turn on and off through Alexa. When I give the command to turn on, only one bulb turns on, sometimes two, sometimes three. How can I improve connectivity and make the commands execute every time.
Also, is the a voice command through Aqara yet?
@Expert Maybe our experts could help ![]()
How are you bound the T2 bulbs to Aqara? By matter or zigbee? Can you see the t2 bulbs in Alexa?
As asked already can you let us know your setup this will help diagnose issues
As the T2 can be exposed to third party ecosystems differently can you let us know if you are connecting via matter to Amazon Alexa, using zigbee mode via a hub such as the M3 or is it a Alexa skill that you used to connect Aqara products?
Hi everyone. The light bulbs are connected by Matter and I can see them on Alexa.
And what Aqara Hub are you using?
I have a M3 hub
Check this post out and it should work…
