I’m planning to install LED strips just above the skirting boards for ambient lighting, with a total length of around 30 metres. I’d like a setup that works well with the Aqara ecosystem.
What LED strips and controllers would you recommend for this project? Would the Aqara LED Strip T1 be suitable, or would a third-party strip with a compatible controller be a better option?
I’d especially appreciate advice on:
Splitting the total length into separately powered sections.
Power supply sizing and power injection to avoid voltage drop.
COB strips versus conventional LED strips with aluminium profiles and diffusers for a smooth, continuous light.
Controlling all sections together through scenes and automations.
If anyone has done a similar installation, I’d love to hear what products you used and any lessons learned.
@hulya, I’m just trying to get one issues resolved with how the Phoscon FLS-M appears in the Aqara app when connected directly via Matter and when this is fixed, I’ll put up a full review.
This is a racking piece of kit that allows for various power supplies and types of LED strips to be connected. You can then either just used the DIP switches to set the connection method (Zigbee or Matter, Matter needed for Aqara) and the language / chip set of the LED strip OR you can use their web browser app via USB-C to config strip lengths (for addressable) and special effects.
I’ll let you know as soon as the issue has been resolved.
Did something close to that in my basement, not 30m but the same idea, and the main thing I learned is that splitting it up makes everything easier.
With the Aqara T1 you’re capped at 10m per controller (2m base + 8m of 1m extensions), so for 30m you’d need 3 kits anyway. Honestly that’s not a bad thing. Each one has its own 24V power supply, so you don’t have to deal with power injection or voltage drop at all. The specs say 0.25A per meter, so a full 10m run is around 2.5A / 60W. Then you just put the 3 strips in a group or a scene in Aqara Home and they act like one light. Since they’re Zigbee repeaters, they help your mesh too.
The downside is that the T1 isn’t COB, so you’ll see the dots if it’s exposed. Above skirting boards, where the light hits the wall from close up, I’d put it in an aluminium profile with an opal diffuser, or aim it at the wall so you only see the glow.
If you really want that smooth COB look, I’d go with a 24V COB strip and a Matter or Zigbee controller, like the Phoscon FLS-M that 2SC mentioned. Same logic: split it into sections of 5 to 10m, feed each section from both ends, and put a power supply around 20% bigger than what the strip needs.
Either way, plan where your outlets or power supplies will go before you start sticking anything to the wall, that’s the part that bit me lol
