I would like to turn on my strip with a growing effect. Starts off, then first segments on, then second, third and go on. All this in 2-3 seconds. Is this posible? Thank you
@alejandro_bot You seem to be looking to achieve a sequential segment lighting effect (segments turning on one after another within 2-3 seconds) when turning on the LED Strip T1. You can contact customer support for assistance. Contact the Aqara Home App Customer Service Team (Home > Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, please click here to create a ticket.
To a degree with several scenes, then an automation to play the scenes.
But the scenes takes at least 2 or 3 seconds each one, i want see all of this transition un 2 seconds, i think is not posible
Was a solution ever found for this? I don’t understand why, if the LED strip is addressable, Aqara can’t implement a simple on/off animation where the LEDs progressively light up from one end of the strip to the other, and reverse the effect when turning off. It would look so cool! @AqaraOfficial
Welcome to the community, Alejandro! Always great to see new faces around here.
To answer your question: Yes, it is absolutely possible if you are using the Aqara LED Strip T1. Since it is an RGBIC strip, each 20cm segment can be controlled individually.
To get that “growing” or wiping effect, you will need to create a custom dynamic scene in the Aqara Home app where the segments turn on one after the other. You cannot make this the default hardware “power button” behavior, but you can set up an automation to trigger this specific scene whenever you want the lights on. Aqara actually uses this exact setup in their marketing for a “staircase welcome” effect, though they usually leave it up to us to actually figure out how to program it in the app!
As a quick bonus tip since I am a huge Home Assistant user: If you happen to be running your setup through Home Assistant, this is even easier. There is a great custom integration available called “Aqara Advanced Lighting” that has a dedicated segment sequence feature. You can set a sequential forward turn on, dial the timer to exactly 2 or 3 seconds, and tell it to hold the lights on at the end.
Let us know if you need any help getting the scene dialed in!
