Light on 5G Pro
The light is on and attracts bugs, setting off the camera. So many unwanted videos. Is there a way to only have the light come on when something bigger than a moth flies past the lens?
@jlandy1962 It sounds like you’re dealing with an interesting challenge! While the Aqara Camera Hub G5 Pro does offer various automation options, such as turning on and off the spotlight, adjusting its brightness, and recognition capabilities, it doesn’t specifically include a feature to differentiate between small insects and larger objects.
For your situation, you might want to explore adjusting the PIR sensitivity settings or using the camera’s humanoid detection feature to minimize false triggers from smaller objects, like bugs. You can manage these settings through the Aqara Home app under the automation or camera settings sections.
If these options don’t fully address your concern, I encourage you to share your experience on the forum. This way, other community members might offer additional solutions or workarounds that have worked for them. Keep experimenting, and happy automating!
What‘s the automatic triggering conditions for the spotlight light you set, my friend? Is it a PIR sensor or something else? We need to optimize the corresponding detection based on the conditions.
