Link Aqara u200 with Aqara G4
I have the Aqara G4 doorbell, and I know it’s possible to link it with the Aqara U200 smart lock so that when someone rings the doorbell, I can unlock the door directly.
However, I keep getting a message saying I need to enable the unlocking feature. I already did that under the Door Lock Working Mode settings.
Unfortunately, the message doesn’t go away, and the function doesn’t seem to work. Am I doing something wrong?
I’m also using the M100 hub.
Thanks!
@shiv_bhasin86 It sounds like you’re on the right track with linking your Aqara G4 doorbell to the U200 smart lock. Let’s see if we can iron out the issue.
Firstly, ensure that the remote unlocking feature is enabled on your U200 smart lock. The U200 supports remote functionalities when bound to the Aqara Hub M3, but you mentioned you’re using the M100 hub. This might be a point to verify since compatibility could vary.
Here’s a quick checklist to follow:
  1. Enable Remote Unlocking: Make sure your U200 is set up for remote unlocking. Double-check your hub compatibility in the Aqara Home app.
  2. Link Door Lock with Doorbell: In the G4 Doorbell settings, navigate to More Settings > Associated Device Control. Ensure the door lock device card is enabled here.
  3. App Configuration: Open the Aqara Home app and head to Accessories > G4 > Device Setting > Linked Device Control. Select your U200 model to ensure it’s properly linked.
  4. Notifications and Control: When the doorbell is pressed, ensure you’re receiving notifications. On the video live page, you should find a “Link” tab to unlock the door.
If these steps don’t resolve the issue, it might be worth checking again if the M100 hub supports all required features for the U200. Additionally, make sure your firmware is up-to-date for both devices.
Feel free to share any more details or questions you might have! If the issue persists, it could be beneficial to reach out to the Aqara Customer Service Team for a more tailored troubleshooting approach.
How top enable remote lock?
@shiv_bhasin86 To enable remote locking on your Aqara Smart Door Lock U200, you’ll need to ensure that the lock is correctly set up with a compatible hub. Here’s a step-by-step guide to help you:
  1. Verify Hub Compatibility: The Aqara U200 lock supports remote features when connected to the Aqara Hub M3. Since you’re using the M100 hub, please double-check if it fully supports remote locking for the U200.
  2. Enable Remote Unlocking in the App:
    • Open the Aqara Home app on your smartphone.
    • Locate your Smart Door Lock U200 in the device list and select it.
    • Go to the lock settings and ensure the remote unlocking feature is enabled.
  3. Link with Other Devices: If you have other devices like the Aqara G4 doorbell, ensure they are properly linked in the Aqara Home app:
    • Navigate to Accessories > G4 > Device Setting > Linked Device Control.
    • Ensure that the U200 model is selected and properly linked.
  4. Firmware Updates: Make sure that both your hub and the U200 lock have the latest firmware updates installed. This can often resolve functionality issues.
If you’re still facing difficulties, it might be a good idea to check if your hub supports all necessary features and settings for remote locking. For more personalized assistance, you may also want to contact the Aqara Customer Service Team.
I believe the unlocking function is activated.
I can open the door via Home Assistant.
I can also open the door remotely.
What I want is simply to link the U200 to my Aqara G4, so I don’t have to spend so much time switching when someone rings the bell."
@shiv_bhasin86 It sounds like you’re already well-versed in managing your Aqara smart devices, and you’ve got the remote unlocking feature working with Home Assistant and other methods. To link your Aqara U200 lock with the G4 doorbell, ensuring a seamless experience when someone rings the bell, follow these tailored steps:
  1. Enable Remote Unlocking: Double-check that your U200 lock is set up for remote unlocking in the Aqara Home app, as it seems to be functioning correctly already.
  2. Link Door Lock with Doorbell: Go into the G4 Doorbell settings and navigate to More Settings > Associated Device Control. Here, you should enable the door lock device card for the U200.
  3. App Configuration: In the Aqara Home app, go to Accessories > G4 > Device Setting > Linked Device Control and ensure your U200 model is selected and properly linked.
  4. Notifications and Control: When the doorbell is pressed, make sure you receive notifications. You should be able to unlock the door from the video live page by clicking the “Link” tab.
It appears you’re doing everything right, but if issues persist, it might be worthwhile to verify compatibility with your hub or check for any available firmware updates for your devices. If these steps don’t resolve the issue, reaching out to the Aqara Customer Service Team might provide a more personalized solution.
Hi Shiv.
Im struggling to bind my u200 with my m100 hub, did you have issues can you give any advice please?
@markvk42 It seems you’re having trouble binding your U200 with the M100 hub. While the specific compatibility details for the U200 and M100 hub aren’t directly mentioned in the reference information, I can offer some general advice that might help:
  1. Check Compatibility: Ensure that your M100 hub supports the U200 lock. The U200 supports remote functionalities when bound to compatible Aqara hubs, so verifying that your hub is compatible is essential.
  2. Setup Process: Follow these steps to attempt binding:
    • Ensure your phone is connected to the internet and that Bluetooth is enabled.
    • Select the U200 from the device list and follow the app instructions for binding.
  3. Firmware Updates: Make sure both your hub and the U200 lock are running the latest firmware versions. Firmware updates can often resolve compatibility issues.
  4. Troubleshooting: If you encounter issues during the binding process, try restarting both your hub and the U200, then attempt the binding process again.
If you’re still experiencing difficulties, please consider reaching out to the Aqara Customer Service Team for more personalized assistance. They can provide detailed support tailored to your specific setup.
