Logitech Pop Buttons and Sonoff Switches Integration Tips
Hey everyone, I’ve been diving into the world of Home Assistant and smart home automation, and I wanted to share my experience with integrating Logitech Pop buttons with Sonoff switches. It’s been a bit of a learning curve, but I’ve managed to get things working smoothly!
Initially, I was excited to use the Logitech Pop buttons to control my Sonoff switches. I successfully added the Sonoff switches to the Logitech Pop app using Emulated Hue, but I ran into some connection issues. Whenever I tried to use the buttons, I’d get an error message saying the devices had lost connection with the hub. It was a bit frustrating, but I didn’t want to resort to using IFTTT because of latency concerns and the tendency for devices to fall out of sync.
After some research and trial and error, I found that the key was to ensure a stable MQTT connection between the Pop buttons and the Sonoff switches. I also discovered that using the Home Assistant MQTT broker as an intermediary helped maintain a more reliable connection. By setting up the Pop buttons as MQTT sensors and configuring the Sonoff switches to respond to MQTT commands, I was able to eliminate the connection issues.
Here’s a quick tip for anyone else trying to integrate Logitech Pop buttons with Sonoff switches: Make sure your MQTT broker is properly configured and that both devices are publishing and subscribing to the correct topics. It’s also worth checking the network settings to ensure there are no firewalls or security groups blocking the MQTT traffic.
I’m really happy with how this setup is working now. The Logitech Pop buttons provide a sleek and intuitive way to control my smart home devices, and the Sonoff switches are reliable and easy to integrate. If anyone has any questions or runs into similar issues, feel free to reach out—I’d be happy to help!
Cheers,
