Looking for a reliable smart plug?
it’s overpriced, not worth
I think Aqara will release some new smart plugs with more features - which are shown on the IFA 25
This for the US Market @DEChrisE
Another option that really does look better and is neat is Shelly. You can wire a basic “Shelly 1” behind the existing plug. These are first-tier devices with tons of features and when you are done, it looks like before you started. I use one in the laundry just to measure power used. Some day I will write an automation to look for when the power usage drops from high to low to notify that the clothes are clean. I have some Third Reality that work too.
What about the Aquara smart plugs? Are they reliable?
Osram Smart+do have good plugs, both inboor and outdoor - Zigbee, MAtter, Wifi
I bought a Matter Power strip on AliExpress, it was a risk because it’s not branded but was the cheapest one I found with also USB 4 USB ports. The only complain is that the USB charger ports are controlled togheter and not a 4 different ports. But the device works flawlessly integrated in Aqara Home and has solid materials.
I know you asked for a plug, but maybe this will be useful for somebody.
I use the Kasa Matter ones - in aqara. You do not get all the features, but onoff and automations are solid
aqara / hue / kasa are some of the best
I’ve used TPLink/Kasa for a long time, and the outdoor double plug has been rock-solid. Lately, however, I’ve been getting the Eve plugs as they extend the Matter/Thread network. Watch out, however, for plugs that are Matter but are only end devices and not repeaters.
I’ve been using my Aqara smart plug for over 5 years. Works great.
I’ve been very happy with my IKEA smart plugs. The newest ones are Matter compliant. GRILLPLATS
Plug, smart
$7.99
I was not able to get the IKEA smart plug to work with my G5 Pro. It could not connect to the network.
Ikea matter devices are not the stabile ones! But they should get a new firmware- maybe they get more reliable then :person_shrugging:t4:
I returned all IKEA devices after a couple of days without success.
As mentioned, the Aqara Smart Outlets are annoying because they block the other port, so I only use them on the top plug and use a different brand for the lower plug if needed. However, they are nice for extending the Zigbee signal from the Hub. Without them, I would not be able to have half of my Aqara devices working, as the ranges would be too far for the Hub to reach them all alone.
One cool smart plug I don’t see commonly is a smart dimmer plug. I use the TP-Link Tapo Smart Dimmer Plug to control a nice lamp that has 5 bulbs in an irregular size. Without the smart dimmer, I would be stuck with the light at full brightness at all times, as there aren’t really smart bulb options for the socket/size type of the bulbs. Another added bonus to this model is that it can control two lights at once and has a remote control to turn it on and off as well as control the brightness.
Thanks for al the inspirations. Iam new and was looking for a good smart plug.
I must say that the new Aqara H2 matter over thread device is really promising. I only have two of them but they have been stable so far, they can manage a good load and they report power. If you use Thread I highly recommend them.
I also have Eve, Bosch and IKEA smart plus Philips Hue and IKEA Zigbee plugs. They all work fine as well as the HomeWizard wifi plugs. I would stay away from the Onvis matter over thread outlets. They are cheap but when I connect them they break my thread network.
But check out the new Aqara H2 if you are in Europe.
I’m using 2 Aqara Smart Plugs (SP – EUC 01). They are great, super reliable and fast, but they are blocking the second plug on the wall.
I agree. I use Meross. I’ve also used Vocolink.
Same experience here with VOCOlinc, which is exactly why I switched. I replaced mine with an Aqara Wall Outlet H2 EU and have had no dropouts since. I prefer the flush mounted variant anyway, since it disappears into the wall instead of blocking a socket.
