Loved everything
Hello community!
I just wanted to share some feedback about my experience with Aqara products. I’ve used quite a few of them over time, and while I’ve had some problems, I still somehow miss Aqara now that I’ve switched to another brand.
One of the products I used was the Smart Lock U200. I installed it on several different doors, but unfortunately the experience wasn’t always great.
On one door, I had a lock where you turn the key further to pull back the latch because there is no door handle on the outside. With this kind of spring/latch retraction mechanism, the U200 sometimes had problems. It would try to turn too far, get stuck, or basically hang itself up. At another point, the lock itself became loose and started spinning without actually operating the door properly.
To be fair, part of that was my own installation mistake. I later fixed it more securely with screws, but even then I never managed to get it working as reliably as I wanted.
So I would definitely recommend that people who have a door without an outside handle, where the key also has to retract the latch, check compatibility very carefully. In my experience, this setup does not always work perfectly.
After I moved, I tried the U200 again on a completely different door. Unfortunately, that setup was also not as good as I had hoped, mainly because I had to rely on the included adhesive mounting solution.
I also had one situation where the smart lock seemed to completely malfunction. I left for work and the door was locked, but some time later it apparently unlocked again by itself. My boyfriend then told me that the door was suddenly standing wide open. I still don’t know exactly what happened, but obviously that was not a great experience with a door lock.
I’ve also tried different Aqara hubs, and I have to say that those actually worked very well for me. The only thing I find a bit unfortunate is that many Aqara products cannot simply connect directly via Wi-Fi and still depend on a hub. I completely understand the technical reasons behind this, but maybe this could be improved in the future so that a hub is not always necessary. (I know, I know… money-making.)
I also used several Aqara GU10 bulbs. Those were actually pretty good. I honestly didn’t pay much attention to the price when buying them, but considering how much they cost, I would also expect a certain level of performance.
I would say they delivered around 80% of what I expected from them. The lights themselves were good, but the biggest issue for me was connectivity and integration.
I’ve used them through Aqara hubs, Matter, Apple Home with a HomePod, and Amazon Alexa. Unfortunately, I repeatedly had situations where something would disconnect, stop responding properly, or just not work as smoothly as I expected.
Another thing I would love to see in the Aqara app is more control over lighting effects. Things like smooth transitions, animations, dynamic scenes, or more customizable effects would be really nice. Of course, this is more of a “nice-to-have” feature than something essential, but I think it could make the whole system feel even more premium.
An open API would also be really cool. It would give people more freedom to experiment with Aqara devices and integrate them into their own smart home setups, Home Assistant, automations, custom software, and so on.
In the end, I actually switched to another smart home brand because I got tired of constantly troubleshooting everything.
But now the funny part: the products I’m currently using are honestly much worse.
So despite having quite a few negative experiences with Aqara, I would actually consider switching back. Aqara definitely wasn’t perfect for me, but compared to some other brands I’ve tried, I still had fewer overall problems.
So yes… I guess I miss Aqara. :sweat_smile:
I’d definitely come back with a few improvements, especially around reliability, Matter/integration, the U200 installation options, and some more advanced software features.
I’d also be interested to hear if anyone else had similar experiences, especially with the U200 and doors where the key has to retract the latch.
Thanks :slightly_smiling_face:
Hello @moura
Thank you for sharing your experience using Aqara devices with us.
Could you tell us which brand you switched to?
Hi! Sadly switched to Nanoleaf. Biggest regret :sweat_smile:
