Magic Screen S100 MarsTech with bulb T2
Hi, I connect 4 Aqara T2 to the Magic Screen S100 switch. The T2 is paired to a M3 Hub via Zigbee. The load from the light group is connected to the S100 L1. But when I tried to activate Mars Tech on the S100, none of the T2 bulbs show up. Only the T1 bulbs on the next room show up, which is connected to a Z1Pro switch and martech enabled.
Any insights?
@mlaihk It sounds like you’re experiencing an issue with your Aqara T2 bulbs not appearing when trying to activate Mars Tech on the Magic Screen S100. It’s great that you’ve already connected the T2 bulbs to the M3 Hub via Zigbee. However, based on the reference information available, there’s no specific mention of Mars Tech compatibility with the T2 bulbs or the Magic Screen S100.
Here are a few steps you might consider trying:
  1. Verify Connectivity: Ensure that all devices, including the Magic Screen S100, M3 Hub, and T2 bulbs, have the latest firmware updates. This can sometimes resolve connectivity and compatibility issues.
  2. Check Settings: Double-check the settings in the Aqara app to ensure that the Mars Tech feature is enabled and configured correctly for the Magic Screen S100.
  3. Compatibility: It’s possible that there might be compatibility issues with the Mars Tech feature and the T2 bulbs on the Magic Screen S100. Since the T1 bulbs work with the Z1Pro switch, there might be a specific compatibility or configuration requirement that’s not met with the T2 bulbs.
  4. Community Collaboration: Given the complexity of smart home setups, sometimes other users might have faced similar issues. Engaging with the community on the Aqara forums might provide additional insights or solutions.
If the issue persists, it might be helpful to contact Aqara’s Customer Service for more detailed troubleshooting. Please reach out to them via the Aqara Home App under Profile > Help & Feedback > Customer Service or by scanning the QR code:
. If you don’t have an Aqara Home account, you can click here to create a ticket. Apologies for any inconvenience this may cause.
Hello @mlaihk
Maybe T2 is not added for mars in S100 yet, write to support with a request to add.
support@aqara.com
@mlaihk You can put a request in this topic and the developers will read it and make a decision on your request. I think this can help speed up this process.
https://forum.aqara.com/t/suggestions-for-improving-aqara-products
