Magnetic Tablet Wall Mount: A Smooth Installation Guide
I’ve been on a quest to find the perfect way to mount my tablet on the wall, and after several attempts, I finally nailed it with this magnetic setup. Here’s how I did it, in case you’re looking for a sleek, detachable solution.
Why Magnetic?
I wanted something that didn’t require drilling too many holes or leaving ugly marks on my walls. Magnets seemed like the perfect solution—they’re strong enough to hold the tablet securely but also allow for easy detachment when I want to move it.
Materials Needed:
  • Neodymium Magnets: I used 30mm diameter magnets with a 5mm thickness. These are super strong and perfect for the job.
  • Plastic Caps: These act as buffers between the magnets to prevent them from snapping too hard and breaking.
  • Epoxy Glue: For attaching the magnets to the tablet’s back.
  • Screws and Anchors: To secure the magnets on the wall.
Installation Steps:
  1. Plan the Layout: Measure where you want the tablet to be mounted. I spaced my magnets 19cm apart horizontally and 10cm vertically to fit my Fire HD 10 tablet.
  2. Drill Holes: Carefully drill holes in the wall for the screws. I used a small drill bit to minimize damage to any hidden cables.
  3. Attach Magnets to the Wall: Screw the magnets into the wall using the anchors. Make sure they’re level—using a water level tool helped me get it right.
  4. Mark Magnet Positions on the Tablet: Temporarily place the tablet on the wall magnets and mark where the magnets will go on the tablet’s back.
  5. Apply Epoxy Glue: Fill the marked areas with epoxy glue and carefully place the magnets on top. Let it cure completely.
  6. Add Plastic Caps: Once the glue is dry, attach the plastic caps to the screws on the wall magnets. This prevents the magnets from breaking when they snap together.
  7. Final Touches: Test the setup by attaching and detaching the tablet a few times to ensure everything works smoothly.
Pro Tips:
  • Test Magnet Placement: Before drilling, test the magnet positions on the tablet to avoid any issues with the tablet’s built-in magnet sensors.
  • Use Cling Wrap: When gluing magnets, place a sheet of cling wrap between the front and rear magnets to prevent glue from getting into the screw heads.
  • Be Patient with Glue: Let the epoxy glue thicken slightly before pressing the magnets together to avoid a messy cleanup.
This setup has been rock solid for over a year now, and I love how seamlessly it integrates into my home setup. It’s perfect for keeping the tablet out of reach of curious hands while still being easily accessible when needed.
If you’re looking for a low-profile, elegant solution for your tablet, I highly recommend giving this magnetic mount a try. It’s a bit of work upfront, but the result is well worth it!
Happy mounting! :rocket:
