Market Co-Creation Survey: W200 Smart Thermostat for EU Market | Share Your Needs on Power, Price & Receiver
UK house, 6 Aqara TRVs, and a Nest that won’t listen to them
2019 Hampshire new-build: Ideal Logic S15 system boiler, unvented cylinder, two heating zones on Nest. One Aqara W600 and five E1 TRVs, all running into Home Assistant.
The problem: the landing Nest sits next to a radiator with no TRV (allowed under UK Building Regs), so the landing hits 23°C and the Nest switches the boiler off while the bedrooms are still below 20°C. The TRVs know the rooms are cold, but nothing tells the boiler.
What I’d want from a W200 for the EU/UK:
  • A 230V / OpenTherm receiver that replaces the Nest Heat Link like for like
  • Two heating zones plus hot water
  • Demand driven by the TRVs and room sensors, not one thermostat on a warm wall
  • Local Matter/Thread control that keeps working offline
I’d rather wait for a proper product than wire up relays. Happy to test and write it up if there’s a beta. Anyone else in the UK solved this cleanly?
@andy124 Welcome to the forum!
Hi, my answers:
  • Battery powered, 2x AAA, like most thermostats, maybe USB-C as backup if can’t have any AAA, but most people don’t have any plugs near the thermostat on the living room.
  • 100€ max, I understand the cost of some of those parts of hardware, but that just increase its price, it has features that you’ll use 5-10 times a year, is it really worth it? I don’t think so. I don’t need a touch screen or mmWave sensor, I need Matter to integrate into Home Assistant, that is the motor of my home, full control over Matter (local), that is important to me.
  • In Spain most heaters/boilers have a separate thermostat (dumb thermostat) on the living room, while the heater or boiler is in the kitchen, the thermostats that you currently find in Spain usually have 2 wires only, a thermostat with a relay should work, if you can create a system that is low power enough, I don’t believe you need a separate device, if not, make a smart thermostat, and instead of Matter, use ZigBee, it’s more power efficient and has better compatibility overall, make sure you create an open documentation for local integrations in any smart-home like Home Assistant (I totally prefer a ZigBee device over Matter, no “matter” :wink: the device type or use-case).
I currently have a Netatmo thermostat, their service last year was horrible, was down more times that I can count, app down, no control with Alexa o Google Home, fortunately, I have it on Home Assistant locally through HomeKit integration, so I was able to control it locally and really had no problem, that is the real benefit from local connections, that is why I always prefer ZigBee over anything else.
Hi ! I am from France and will be very interested in this smart and premium thermostat. The lack of premium feeling is what is preventing me from buying one already on the market.
If you plan a forum test, you could definitely count me in !
Q1: Preferred power supply mode for W200 EU
With a premium screen, I really fear that the battery life will be way to short. But if it can have a 2-year battery life, it’s the way to go !
If not, the usb-c external power supply is the best option since you can put it on a table or mount it in your wall. From an electrical and wall “deterioration” point of view, it’s the same than having live and neutral hardwire, but this hardwire option cannot be put on a table for those who don’t want to deteriorate their wall !
Q2: Expected retail price (EUR)
Definitely no more than the Apple Home Climate smart thermostat (200€)
Shelly display are under 159€ but are bigger.
SONOFF - NSPanelPRO Zigbee 3.0 is under 100€ but their is cheaper option.
A fair price, considering the competitive market, is between 50 and 100€.
Q3: Is a separate wireless Receiver module necessary?
It will increase the price so no.
But a separate zigbee/matter emetter/receiver module (to be plugged on the boiler/heater) that would connect to a zigbee/matter hub, and as a result would be accessible by the smart thermostat through matter or zigbee would be a great solution. It would be optional so would not increase the thermostat’s price.
Q4: extra comments regarding installation troubles, functional demands or other optimization ideas
It would be nice to preserve a zigbee protocol, in addition to matter, to target a broader market.
It would dramatically expand the market to let home assistant uses the screen as a display for whatever the want.
Thanks @starlitter, really appreciate the warm welcome! Looking forward to being part of the community.
