Hey guys, I’m kinda stuck here trying to figure out which Aqara devices play nice with Matter. I’ve got a mix of smart home gear and really want everything to work together smoothly.
From what I’ve read, some Aqara products are Matter-certified, but the info feels scattered. Like, will my existing Aqara sensors work with Matter hubs? What about the newer devices?
If anyone’s already gone through this setup, I’d love to hear:
- Which Aqara devices you’ve successfully paired with Matter
- Any weird quirks or workarounds needed
- Whether it’s worth waiting for more Matter support
Bonus points if you’ve tested across different ecosystems (Apple/Google/Amazon). Trying to avoid buying stuff that’ll just collect dust.
Appreciate any real-world experiences you can share! This Matter transition feels like navigating a maze blindfolded.
@NestNerd Hey there! I totally get why you’re feeling a bit overwhelmed with the Matter transition. Aqara has indeed stepped into the Matter ecosystem, but understanding which devices are fully compatible can be a bit of a puzzle.
Currently, some Aqara devices like the Hub M3, Motion Sensor P2, and Door Sensor P2 support Matter. Moreover, Aqara 3.0 Zigbee gateways, excluding the G2H Pro, can act as Matter bridges, allowing connected devices to communicate with other Matter-compatible ecosystems.
To address your questions:
- Existing Aqara Sensors: If they’re connected via a Matter-compatible hub or gateway, they should work with Matter hubs.
- Newer Devices: Check if they support Matter natively or through a compatible hub.
- Ecosystem Testing: Aqara devices via Matter can integrate with platforms like Apple Home, Google Home, Amazon Alexa, and Samsung SmartThings.
As for quirks or workarounds, while the transition is generally smooth, there might be minor setup nuances depending on the ecosystems you’re using. It’s often worth checking community forums or the Aqara community for shared experiences and insights.
Whether to wait for more Matter support depends on your immediate needs and future-proofing plans. More devices are being certified, so if you can hold off, you might benefit from broader compatibility soon.
Feel free to share your experiences or any specific challenges you face. The community here is always eager to help and learn from each other!
