Hello,
Matter specs specifies cluster DoorLockspecifies OperatingMode attribute (see specs 5.2.6.15).
Could you add support for Operating Mode being selectable as a select box in the Aqara app?
Regards
Hello,
Regards
dear ludovic_boue, Please describe it in more detail.
The U200 also supports these “OperatingMode” attribute according to the compliance document:
Hi, Thank you for your feedback. But we have found that most ecosystems and other locks do not support this feature. We will continue to investigate the level of user demand for this feature. Thank you.
The goal is to be able to select the operating mode described in the specifications directly from the Aqara application.
This attribute allows you to change the lock’s operating mode.
This Matter attribute is implemented on the Aqara U200 product because it is mandatory for compliance testing.
Example
