Hi everyone, I wanted to share my recent experience migrating my Hassio setup from a Raspberry Pi to an Intel NUC. I’ve been using Hassio for a while now, and while the Pi worked well, I wanted more power and reliability for my growing smart home setup.
The Process
I started by installing Ubuntu on the NUC, followed by Docker and the required components. Bringing up the Hassio image went smoothly, and I was able to log in without any issues. The next step was transferring my backups from the Pi to the NUC. I copied the .tar files from the Pi’s backup folder to the NUC and navigated to the snapshots section in Hassio. I selected “wipe and restore” with everything checked, expecting a seamless restore. However, the connection dropped, and nothing happened. No logs were written, which was perplexing.
What I Learned
After some research and trial and error, I realized that the issue might have been related to the backup files themselves. I tried restoring a smaller backup, and it worked perfectly. It seems the full snapshot was too large for the initial restore process. I also discovered that ensuring Docker is properly configured and that all dependencies are up to date is crucial for a smooth migration.
Tips for Others
If you’re planning a similar migration, here are a few tips:
- Start Small: Test the restore process with smaller backups before attempting a full system restore.
- Check Docker Configuration: Ensure Docker is running correctly and that all required components are installed.
- Backup Logs: Even if the restore fails, having logs can help troubleshoot the issue.
- Consider Incremental Restores: If a full restore isn’t working, try restoring services one by one.
While the initial attempt was frustrating, it taught me a lot about the restore process and the importance of thorough preparation. The NUC setup is now running smoothly, and I’m excited to expand my smart home further. If anyone has questions or tips about migrating Hassio, I’d love to hear them!
Happy automating! ![]()
