Migrating Smart Home Devices to Surety: A Smooth Transition
I recently made the switch from Vivint to Surety for my home security system, and I wanted to share my experience in case others are considering a similar move. After years of frustration with Vivint’s proprietary system, I decided it was time for a fresh start. I chose the 2Gig GC2e panel because it was compatible with my existing sensors and promised better integration with my smart home devices.
The migration process wasn’t without its bumps, but I found Surety’s setup surprisingly straightforward. I was able to integrate my zwave locks, thermostats, and cameras without much hassle. One thing I was particularly impressed with was Surety’s monitoring plans—they offer flexible options that fit different lifestyles. While I initially thought the pricing might be a sticking point, the first-month free trial made the transition much easier to swallow.
I also wanted to mention the importance of primary connectivity. I configured my system to use WiFi as the primary connection with cellular as a backup, which has worked perfectly so far. For anyone looking to make the switch, I recommend checking out Surety’s support resources—they have some excellent guides and troubleshooting tips.
Overall, I’m really happy with how everything turned out. It’s been a while since I felt this confident about my home security setup. If you’re on the fence about switching, I’d say give Surety a try—you might be pleasantly surprised! :rocket:
