I recently went through the process of migrating my SmartThings Classic account to the new SmartThings (Samsung Connect) platform, and I wanted to share my experience and some tips for anyone else going through this transition. Spoiler alert: It was a bit tricky at first, but definitely manageable with a little patience!
When I first logged into the new app after migration, I was a bit disoriented. My devices and hubs weren’t showing up as expected, and I received a message about needing to connect a hub. I checked my account details, but I didn’t have the original hub code anymore. I felt a bit stuck, but I decided to take it step by step.
First, I installed the new SmartThings (Samsung Connect) app on my phone. To my relief, all my devices were listed there, but clicking on any of them resulted in an “Unable to connect” error. I realized that the migration process had moved my devices to the new app, but they weren’t fully integrated yet.
After some research, I found out that I needed to re-pair my hub with the new app. I powered off my hub, waited a minute, and then powered it back on. This seemed to reset the connection, and I was able to add it to the new app. Once the hub was reconnected, my devices started showing up again, and I could access them without issues.
One thing I learned is the importance of keeping backup codes or notes for hubs and devices. If I hadn’t been able to reset the hub, I might have had to go through a more complicated setup process. Thankfully, the new app made it relatively easy to re-add my devices and restore my routines.
I also took this opportunity to organize my devices and automations. It was a good chance to streamline my setup and remove any redundant devices or rules. I even discovered some features in the new app that I hadn’t used before, like more detailed device status updates and improved integration with other smart home platforms.
If you’re migrating from SmartThings Classic, here are some tips I’d recommend:
- Backup your current setup: If possible, take screenshots or notes of your devices, automations, and routines before migration.
- Reset your hub: If you encounter connection issues, try resetting your hub to establish a fresh connection with the new app.
- Take your time: Don’t rush the process. Take it step by step, and don’t hesitate to consult the app’s help section or community forums if you run into problems.
Overall, migrating to the new SmartThings platform was a positive experience. It gave me a chance to refresh my setup and explore new features. If you’re considering making the switch, I say go for it—it’s worth the effort!
Happy smart home tinkering! ![]()
