I suspect that the air pressure reading isn’t being passed to Home Assistant via the Matter Bridge. I am experiencing the exact same behavior in my HA setup (pressure is missing).
However, if you connect the sensor directly via Zigbee2MQTT, the pressure value is correctly supported and exposed. You can verify the supported data points here: Aqara WSDCGQ12LM control via MQTT | Zigbee2MQTT
I’ve been looking for a sensor that covers localised atmospheric pressure to help me track any correlation between certain migraine symptoms etc, is the T1 sensor pretty good at this or is there another you’d recommend? I’d like to get the figures in Apple Home either natively via matter if/when Apple supports the measurement or via Homebridge or HomeAssistant if needed. I’d appreciate any/all insight.
With iOS 27, the Apple Home app currently does not display air pressure readings, neither for my Ecowitt weather station (connected via Matter) nor for my Aqara sensors (connected via HomeKit). It only shows temperature and humidity.
The Aqara Home app displays the readings from the Aqara sensors and the readings from the Ecowitt weather station connected via Matter. However, you can only link Aqara temperature sensors to a heating thermostat, not to temperature sensors connected via Matter.
As mentioned above, Home Assistant does not display air pressure readings from the Aqara sensors via the Matter bridge (Aqara hub). The readings from my Ecowitt weather station are available, and there are also several weather integrations that provide readings from nearby weather stations. As I mentioned earlier, you should be able to see the air pressure readings when you connect to the Aqara sensors via Zigbee2MQTT using a Zigbee coordinator.
I don’t use Homebridge, so I can’t comment on it.
Do you just want to view the values in an app, or do you want to use them for automation or something more specific?
