Monitoring Homey System Load and Integrating Zigbee Devices: Tips and Tricks
Hey everyone, I wanted to share some insights and tips based on my recent experiences with Homey and Zigbee devices. It’s been quite a journey, but I’m happy to say I’ve figured out a few things that might help others as well!
First off, I recently discovered how to monitor the system load on my Homey. It’s been incredibly useful for optimizing performance. If you’re curious, here’s a quick rundown of how I set it up:
  1. HomeyScript Setup: I created a script to pull system load data, which includes metrics for 1, 5, and 15 minutes. This helps me keep track of how much strain my system is under, especially during peak usage times.
  2. Flow Automation: I set up flows to trigger every 1, 5, and 15 minutes. These flows update tags with the current system load values, making it easy to monitor in real-time.
  3. Home Assistant Integration: For those using Home Assistant, I’ve shared how to pull these values into MQTT and create sensors. It’s a great way to visualize the data in a dashboard.
What’s been most helpful is seeing how different activities impact the system load. For instance, during backups or heavy automation runs, I can see the load spike and adjust my settings accordingly.
Now, moving on to Zigbee devices—this has been a bit of a learning curve for me. I’ve been experimenting with various Zigbee sensors and switches, and here’s what I’ve learned:
  1. Firmware Updates: Always ensure your Zigbee devices are running the latest firmware. I’ve noticed significant improvements in reliability and performance after updating a few devices.
  2. Network Health: Regularly check your Zigbee network health. I use the built-in tools in Homey to scan for any issues or devices that might be causing interference.
  3. Pairing Tips: When adding new Zigbee devices, patience is key. I’ve found that placing the new device close to the coordinator during pairing significantly improves success rates.
  4. Battery Life: Speaking of sensors, I’ve been keeping an eye on battery levels. It’s amazing how consistent some brands are compared to others. I’ll be sharing more on this in a future post!
If anyone has tips or tricks for optimizing system load or Zigbee performance, I’d love to hear them. Let’s keep the knowledge flowing!
Cheers,
