Morning Automation Success with Vera Edge
I’ve been absolutely thrilled with my Vera Edge setup, especially after successfully automating my morning routine. I wanted to share my experience in case anyone else is looking to achieve a similar setup.
I set up my Vera Edge to gradually brighten my bedroom lights starting at 7:00 AM. The idea was to simulate a sunrise and help me wake up more naturally. I programmed it to go from 0% brightness to 100% over a 30-minute period. It worked perfectly for the first week, but then I noticed something odd—it would brighten, turn off, and restart the process over and over.
At first, I was a bit puzzled. Why would it do that? I checked the settings and realized that I had accidentally left the automation rule in a loop. Once I turned off the rule and reprogrammed it to stop at 100%, everything worked like a charm.
What’s been even more impressive is how reliable Vera Edge has been. I’ve had zero issues with connectivity or performance, and the integration with my other smart devices has been seamless. Plus, the Vera Edge app is user-friendly, making it easy to tweak settings even for someone like me who’s still getting the hang of smart home tech.
If anyone else is looking to set up a similar morning routine, I’d highly recommend starting simple and testing each component before layering on more complex automation. It’s also worth checking out the Vera Edge community forums for tips and troubleshooting advice. Happy automating! :sun_with_face:
