Motion Sensor & Sunset Automation Setup
I’ve been trying to set up a smart lighting system where my outdoor lamps turn on when motion is detected, but only after the sun has set. It’s been a bit of a challenge, but I think I’ve got it figured out! Here’s what I’ve learned:
First, I wanted the lights to come on 30 minutes after sunset. I messed around with the sun events in my smart home app, but nothing worked as expected. I kept getting the lights turning on too early or not at all. It was frustrating, but I kept at it!
Here’s what I discovered: I needed to combine two conditions—motion detection and sunset timing. I set up a flow where the lamp activates only when both conditions are met. Now, it works perfectly! The lights stay off during the day and only turn on when motion is detected after the sun has set.
One thing I learned is to double-check your time zones and location settings. Even a small error there can throw off the entire system. Also, make sure your motion sensor is positioned correctly to avoid false triggers from things like passing cars or pets.
This setup has been a game-changer for my evenings. It’s so much more convenient than manually turning the lights on and off, and it adds an extra layer of security to my home. I’m really happy with how it turned out!
If anyone has tips on optimizing this setup further, I’d love to hear them! :crescent_moon::sparkles:
