MQTT Automation with Shelly Button1: A Smooth Setup Journey
Hello everyone! I wanted to share my experience setting up MQTT automation with the Shelly Button1. While it was a bit of a challenge at first, the process turned out to be quite rewarding once everything was in place.
I initially tried using the Shelly integration directly, but it didn’t work as expected. After some research, I decided to switch to MQTT, which opened up a whole new level of customization. The key was setting up the MQTT blueprint correctly. I found that specifying the device ID from the Shelly Button1’s web interface was crucial for subscribing to the right MQTT topics.
One thing I learned is the importance of having a reliable MQTT broker. I configured both Home Assistant and the Shelly Button1 to use the same broker, which ensured seamless communication. The Button1’s ability to detect single, double, triple presses, and long presses made creating varied automations a breeze.
For anyone looking to set this up, I recommend starting with the blueprint provided in the community. It simplifies the process significantly. Just remember to adjust the device ID and ensure the MQTT topics are correctly subscribed to. I also found it helpful to keep the Shelly Button1 on USB charging to access its web interface easily.
Overall, this setup has added a new layer of convenience to my smart home. It’s amazing how a simple device like the Shelly Button1 can enhance your automation capabilities when paired with MQTT. If you’re considering this, give it a try—it’s definitely worth the effort!
Happy automating! :rocket:
