I recently upgraded to OpenHAB 4.1 and encountered some challenges while configuring the MQTT broker. Having used MQTT extensively in OpenHAB 2, I was excited to see how the new version would handle it, but the process wasn’t as straightforward as I hoped. Here’s my journey and the solutions I found!
The Challenge
In OpenHAB 2, I used a mqttbridge.things file with a simple configuration to connect to my MQTT broker. However, in OpenHAB 4.1, the configuration process has changed significantly. Initially, I tried replicating my old setup but faced issues with connectivity. The broker wouldn’t start, and I couldn’t figure out why.
The Solution
After some research and trial and error, I discovered that OpenHAB 4.1 requires a different approach to MQTT configuration. Instead of a .things file, I needed to configure MQTT directly in the services/mqtt.cfg file. Here’s what worked for me:
properties
mqtt:
enabled=true
host=192.168.10.112
port=1883
client_id=OpenHAB4
username=ppp
password=ppp
secure=false
I also ensured that the MQTT add-on was installed and enabled in the Paper UI. Once I made these changes, the broker started without any issues!
Tips for Others
- Check Logs: If you’re having trouble, check the OpenHAB logs for error messages. They often provide clues that can help you troubleshoot.
- Configuration Location: Remember that MQTT configuration in OpenHAB 4.1 is handled differently. Stick to the
mqtt.cfgfile for simplicity. - Community Support: Don’t hesitate to reach out to the OpenHAB community forums. Someone has likely encountered the same issue and can offer guidance.
While the transition to OpenHAB 4.1 had its bumps, I’m thrilled with the improved functionality and user interface. Configuring MQTT was just one piece of the puzzle, and now that it’s sorted, my setup is more efficient than ever. If you’re upgrading, take your time with the configuration and don’t be afraid to experiment!
Happy automating! ![]()
