MQTT Configuration Simplification for Multiple Devices
I’ve been diving into the world of MQTT configurations for my smart home setup, and I must say, it’s been quite the learning curve. I’ve been using the MQTT1 binding for ages, but with my recent system upgrade, I decided to switch to the new MQTT binding. While I appreciate the flexibility of working directly in config files, I’ve found myself a bit overwhelmed with the amount of manual setup required for multiple devices.
Specifically, I have 10 Zigbee Aqara temperature sensors connected through zigbee2mqtt. To my dismay, it seems I need to add a separate section for each sensor in my ‘things’ file and then define individual items in the ‘items’ file. This feels incredibly repetitive and time-consuming, especially when all these sensors serve a similar purpose. I can’t help but wonder if there’s a more streamlined approach, like configuring a single ‘thing’ template for each sensor type and then specifying unique identifiers in the items file. Unfortunately, it seems this isn’t currently possible, which is a bit disheartening.
That said, I’ve discovered a few workarounds that might help others in similar situations. For instance, using templates or scripts to automate the configuration process could save a lot of time. I’ve also come across some community-created tools that simplify the setup for multiple devices, though they aren’t officially supported. It would be fantastic if the MQTT binding could incorporate some of these features natively, making it more accessible for users who aren’t as comfortable with manual configurations.
In the meantime, I’m trying to make the best of the current setup. I’ve started organizing my config files into modular sections, which makes it easier to manage and update. If anyone has tips or tricks for handling multiple MQTT devices more efficiently, I’d love to hear them! Let’s keep the conversation going and help each other navigate this exciting but sometimes complex world of smart home automation. :rocket:
